Old 01-02-2009, 01:21 AM
Christian Niklasso Christian Niklasso is offline
Question Even Radio Frequensyon Delco Radio
Hi!
I have a Silverado -00 With the standard built in stereo, and i wounder if it is possible to set the standard Delco CD/Radio to an even FM radio frequensy? Since here in Sweden we the most radio stations is transmitting on even frequenses for example xx.4, xx.6, xx.8 but my i can only tune my radio to uneven xx.3, xx.5, xx,7 and so on...
And i friend of mine said that they hade a Dodge truck in wich you held a button and then you could tune in even frequenses an this was also a Delco radio so I wounder if theres a simular way of doing it on my truck.
/Christian
Old 01-02-2009, 08:47 AM
j cAT j cAT is offline
Re: Even Radio Frequensyon Delco Radio
Originally Posted by Christian Niklasso
Hi!
/Christian
having lived in europe I know that the bandwidth is also different..I have see on other radio equiptment this switch to change to your areas broadcast frequencies.
because you have an oem delco radio ,,,info on this equiptment is limited[as I'm sure you know] perhaps you should consider an up grade to an aftermaket receiver with superior performance, that best matches your needs..this then can be transferred to any other vehicle ,if you dump the gm vehicle....
Old 01-02-2009, 09:52 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I'm with j cAT...most aftermarker radios have the option of switching to European frequency adjustment (0.05 or 0.1 increments). Alternatively, you might ask a Saab dealership (owned by GM) if they might know the right key sequence. Good luck, and let us know if you find the answer!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
