Old 01-01-2009, 06:40 PM
tleeburks tleeburks is offline
94 C1500 silverado won't start, but turns over
I have a 94 c1500 that cranks over, turns over but doesn't start i spent today replacing the distributor cap/rotor to no avail. I also open up the breather and checked for fuel being sprayed into the carburator and it was dry and i seen no evidence or smell of gas/fuel. so, do you think it can be the fuel pump. if it is, is it easy to replace. i know you have to drop the tank. i looked online and they sell the pumps for 50-60 bucks at your usual auto parts places. question: it says that the warranty isn't any good without replacing the strainer. how much is the strainer? any advice? thanks
Old 01-01-2009, 07:42 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 94 C1500 silverado won't start, but turns over
A fuel pressure test will confirm- as well as jumping 12v to your fuel pump prime connector underhood. Does it fire with carb cleaner sprayed into air intake?
Remember, with a pickup truck- you have the option of lifting the bed off to access the F/P- no need to empty the gas tank that way....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 01-03-2009, 08:23 PM
htrd69rs htrd69rs is offline
I had a very similar problem, wiggle the grounds on your intake behind the thermostat housing. I found a loose ground after a bunch of work & money.
