main & rod bearings torque
does anyone Know the main bearing torque and rod bearing torque for a 2002 3400 engine
Re: main & rod bearings torque
welcome to A/F and happy new year. the mains are torque to 37foot lbs then a extra 77 degrees or just under a 1/4 turn. rods are 18 foot lbs + 100 degrees ( just over a 1/4 turn ) this is for the 2001 to 2003 3.4L good luck.
: NOTE 2000 3.4 rod torque is different than the 2001 to 2003 3.4L engines.
Connecting Rod Bearing Bolt
15 lb ft
Crankshaft Main Bearing Cap Bolt/Stud
37 lb ft
ETA: I see I was a little slow on the draw.... we're the same on the mains, but a little different on the rods...all I can say is my specs are from what should be a reliable factory resource...
2000 Venture - repairs to date: LIM gasket, water pump, wiper park position, front wheel bearings, rear wheel bearings, flickering lights, blower motor resistor, door speaker corroded, rear hatch handle, rear wiper motor, front struts, busted sway bar, LCA bushings, hard shifting tranny (new solenoids!) |
Where are you pulling your info from?
