Roadmaster starting problem
i have a 94 buick roadmaster lt1 , its acting like the car battery is dead but ive put a brand new battery in it and it still acts like its dead anyone have any idea whats wrong. when i turn the key the dash lights go off and it is like i have a dead battery it wont even make 1 revolution. could it be my opti is bad? it is a stock engine with 115,000 miles.
Re: Roadmaster starting problem
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Thanks for the replies everyone they are greatly appreciated. The cables and terminals on the car are brand new. i replaced them along with the battery and the ignition coil. still no luck yet.
What about the starter and solenoid, have you checked the function by jumping the purple wire to battery postive (+)? Did this problem start before you installed the new battery?
No i have not jumped the starter i will have to try that. The problem started before i bought the battery. Do i just tap the wire with a 12 volt battery or what?
Hello. Just found a problem people! Pulled my starter and found out that the case around the neck where the gear engages the fly wheel is cracked almost all the way around and the gear is kind of at an angle. I think it was jammed in there preventing it from spinning. Going to change starter and see if the end result is positive.
Starter change did the trick. Problem solved. Thanks to all.
