Old 12-31-2008, 07:19 PM
bratt bratt is offline
head bolt snapped. need advice on drill bit to use to drill it and extract
wha kind of metal drill bit would work best to drill out a head bolt.
one of my head bolts snapped while installing!
Old 01-02-2009, 09:05 PM
OldSVTGuy OldSVTGuy is offline
Re: head bolt snapped. need advice on drill bit to use to drill it and extract
Do you have any material above the block?? If so, I would weld another bolt on top. Use some PB Blaster and let it sit for a while. Also, might use some heat. If you have no material above the block, then you have to start drilling it out. If you have quite a bit of material above the block, you might try pounding an impact socket on it to try and remove it. Or, you could grind it squire and use a 12-point socket.
If possible, take the block into a machine shop and let them do it - get a quote first.
Be very careful about using any EZ Outs because if they break, you are about totally screwed as they are hardened steel and cannot be drilled out - ask me why I know?
If you decide to drill it out, use a good, carbide tipped drill and try to start drilling right in the center - use a punch to get a starting point. Use larger and larger drills until you can get it very thin. You will most likely screw up the threads, so plan on a helicoil job.
It is much preferrable to take it to a machine shop - they are equipped for these issues.
Good luck whatever you decide.
