Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-31-2008, 04:46 PM
Eclipser80 Eclipser80 is offline
Send a message via AIM to Eclipser80
High Idle...still happening
So My dad and i just took apart the throttle body..everything is working. so we took apart the ecu harness and the cable bunch underneath it. we checked all the cables from the ecu to the IAC, all checked out fine. So now we are thinking the computer is just fried.. any one have any ideas for what it could be?
95 eclipse gs non turbo 420A, is the car.
1995 Mitsubishi Eclipse GS Non-turbo
Old 01-09-2009, 04:36 PM
Re: High Idle...still happening
I guess my problem is an anonomoly..i can't find any forums on what to do with out them saying check the BISS screw..except I dont have one so its all pointless..
Old 01-14-2009, 12:19 PM
Hey so more detail as to when the problem occurs.
It happens mostly when its warmed up and driving. when i come to a stop light from driving it will rev until i come to a complete stop and then it slows to 750 and starts surging from 1k-2k usually. when im driving occasionally the car will jerk and the CEL will go off and it will be fine for a couple minutes and it will come back on. but theres other times when the light just never comes on from start up to shut down.. thats why its so confusing as to what it could be. I'm going to pull off the TB tonight and clean it again to double check. is there anything else i could do or do i have to finally take it to a shop and let them hack at it. the codes again its spitting out is P0505 and P1294..anything that you guys can come up with..and I mean anything!
Old 01-15-2009, 06:49 PM
High idle...SOLVED!!!
so it was the coolant was about a half gallon empty so the ECU was reading it wrong. and now it purs like a kitten at 750rpm
Old 02-02-2009, 04:51 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
as i dont know anything that has been goin on with the car heres the things i would recomend to cheack, the iac tps sensors, also if uve had any work done make sure teh timeing is perfect when i rebuilt mine it was 1 tooth off and idled at about 3k
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-02-2009, 05:26 PM
we replaced all the sensors known to man on the thing basically. all but the 02 i believe. and the timing wouldn't cause the surge i dont think would it?
Old 02-02-2009, 08:11 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Yes it is possible.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-02-2009, 09:45 PM
ill check that
Old 02-02-2009, 10:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-02-2009, 11:49 PM
yeah that accounts for the high idle but it also surges between 1k and 2k. so i didnt know if it being off could cause it to surge like that. also it happens to idle really high when im coming to a stop. it just slowly rises to 3k and stays until i come to a complete stop and then it drops to 1k and starts surging or stays idling at 2200
Old 02-03-2009, 06:34 AM
Holset powered 420a
Wait till the car is idling good and disconnect the IAC sensor and see if it stops your problem. It sounds like the IAC is working fine but the ECU may not be controlling it properly.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-03-2009, 11:40 AM
that's what we are thinking because this is the 3rd IAC that we've put in it
