Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 12-31-2008, 12:36 PM
JohnDD JohnDD is offline
Blower resistor problem
I have a 1998 Honda Civic. My heater fan was only working on full speed. I found that the blower resistor was burned out (open circuit). Replaced the resistor and everything was fine for one day! Now I have the same symptoms (and probably burned out resistor). Fan still runs fine at top speed.
Fan must be drawing too much current? Anyone have suggestions re fix? (Do I need to replace the fan, even though it works fine at top speed)?
Old 01-06-2009, 09:35 AM
Copytech99 Copytech99 is offline
Re: Blower resistor problem
Have you tried to turn it by hand to see if it is tight ??
Old 01-06-2009, 03:05 PM
Good idea to rotate by hand. But do I need to remove the fan to do that?
Old 01-06-2009, 05:09 PM
Not sure on the 6th gens, If you have a cabin filter try to access from there. You could also measure the current draw for the fan (not sure of specs though)
Have you found one of the free factory service manuals for your Civic on the web ??
Very helpful and free.
Old 01-15-2009, 12:03 PM
azntech630 azntech630 is offline
the blower motor has mechanical resistance therefore causes to draw high amperage which the resistor only draw a certain amount. i suggest changing the motor or if u know how to rebuild the armatures, windings all sorts of stuff.
Old 04-28-2011, 07:48 PM
Replaced the fan motor and all is well. Took the old motor apart and oiled the bearings and now have a spare motor.
Original problems was that motor was drawing too much current due to seized bearings.
The Following User Says Thank You to JohnDD For This Useful Post:
speediva (05-12-2011)
