Old 12-30-2008, 06:53 PM
MdPhoenix's Avatar
MdPhoenix MdPhoenix is offline
Send a message via ICQ to MdPhoenix Send a message via AIM to MdPhoenix
2000 Caravan ECM failure?
My neighbor took her 2K Caravan to Autozone to pull the code. It came back with the following,
"ECM Internal fault. ECM Unable to communicate on SPI Line. Probable cause: Shorted Input Sensor, Shorted Electrical Circuit, or Failed ECM."
Besides the obvious stated, any ideas where to start or what it could be? Is this common or is the ECM screwed?
Old 01-01-2009, 04:14 PM
MdPhoenix's Avatar
Re: 2000 Caravan ECM failure?
I sincerely hope the lack of response is due to the holiday.
Old 01-07-2009, 09:31 AM
MdPhoenix's Avatar
Not even a suggestion. Really. No one else has had this issue? Sigh.
Old 01-07-2009, 10:16 AM
jpb53 jpb53 is offline
P0601GenericInternal Control Module Memory Check Sum ErrorI take it this the code? Yes replace the computer is the fix. warrantied for 8 yrs or 80k miles.
Old 01-07-2009, 01:06 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
A bit more info on a 601 code: http://www.obd-codes.com/p0601
FYI - ECM or Electronic Control Module is a generic code used to ID the engine computer. On a Chrysler Corp minivan it's known as the Powertrain Control Module or PCM and yes, I for one was gone for two weeks.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-08-2009, 11:30 AM
MdPhoenix's Avatar
Thanks for the replies everyone.
I just called her. She states there's no actual code on the printout.
Just for grins, I'm going to see if I can find one on the cheap. Where's the computer located in this beast?
Old 01-08-2009, 12:14 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Nothing conclusive here but it does show evidense you are dealing with a P0601 code: http://autoforums.carjunky.com/Autom..._p0601_P36033/
The PCM is on the drivers side fender wall outboard of the battery. I'll see if I can find a pic.
Old 01-14-2009, 10:11 AM
MdPhoenix's Avatar
Thanks. I've done some extensive research today and everything points to replacing the module. Can I replace the computer with a used one? If so, I'm guessing it has to be programmed by the dealer? Does anyone know if it's possible to drop a used computer in the van temporarily to verify that this fixes the issue?
Old 01-14-2009, 12:19 PM
Not a good idea. All the modules talk to each other. Say the vehicle you are working on is not equipped with VTSS (vehicle theft security system) and you install a PCM from a vehicle that is equipped; you will have a no start condition. The PCM will be looking for a signal from the BCM ( body control module ) that is not there.
Old 01-14-2009, 03:26 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Ya, that's been an issue. Logic tells me if you can verify you are matching up a VTSS PCM to a VTSS equiped van or non equiped to a non equiped...then it should be ok to slave in the PCM. Make sense jpb?
Old 01-14-2009, 04:25 PM
That's the only way it will work properly.
Old 01-14-2009, 06:55 PM
rhandwor rhandwor is offline
Their should be a number on the computer you have to match.
Old 01-14-2009, 07:14 PM
It hit me on the way home that what I said earlier is not entirely correct. Thinking about too many cars at one time! If the van MD is working on is not SKIM equipped it will not work properly. You will have a vin mismatch. If the key is grey it is skim equipped and used is not a good choice.
Old 07-15-2009, 01:04 PM
f117_14 f117_14 is offline
I'm just trying to understand what has been posted so far. I pulled a P0601, hence I need a PCM, that I understand. My car has VTSS (vehicle theft security system). Would I be able to put in a used PCM from a car that also has VTSS?
The dealer is quoting me 920$ for the PCM and 220$ for labor, 120 for reprogramming. Trying to save some cost on the part....
Mine is an 02 caravan 3.3l. Those used PCMs are hard to find too...
Old 07-15-2009, 01:51 PM
http://autocomputersupply.com/index....on=custom&ID=5
