Old 12-30-2008, 04:58 PM
Bartmeadows Bartmeadows is offline
Intermittant miss
Im new to this forum, I have a 95 K1500 with 5.7 auto trans what my problem isthat i have an intermittant miss at all rpms it will back fire and feel like its has a fuel problem and other times it runs fine it has now codes stored. beforei start throwing money it i thought i would try to get a few ideas what the problem may be. thanks for any help
Old 01-01-2009, 02:21 PM
2000CAYukon 2000CAYukon is offline
Re: Intermittant miss
Can you post the codes that you now have? That would help. Backfire, could be EGR operation, ignition coil, wires and or plugs, pickup coil, ignition module or a mechanical issue.
Are the injectors dripping at idle? The Fuel pressure regulator is in the TBI unit and the diaphram could be leaking.
//2000CAYukon
Old 01-02-2009, 10:28 AM
I have no scan tool, but by grounding A and B together all i get is 12 the handshake code with no others i checked this a couple times, it seams strange that there wouldnt be any codes stored
Old 01-05-2009, 09:32 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Does it only do it when going uphill? If so, then I would suspect fuel pump or fuel filter.
I would start by replacing fuel filter.
If it does it under all load conditions, then I would look at cap and wires. Also check for vacuum leaks.............
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
