Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-30-2008, 01:53 PM
sdj002 sdj002 is offline
1992 Olds 3.1 no start
I have replaced the fuel pump and testing it at the rail. It has 42psi. Car will crank just fine, but won't start. If I spray fuel into the TB it will run. Is there a way to test the fuel injectors to see if they are getting power? Any other ideas would be appreciated!! Thanks!
Old 12-30-2008, 02:42 PM
maxwedge maxwedge is offline
A990 racer
Re: 1992 Olds 3.1 no start
Get a noid lite on the injector connector or check for 12v at the harness going to them for easier access, do you have good stong spark?
Old 02-23-2009, 01:28 PM
David3100 David3100 is offline
Check the wiring from your Crank position sensor that runs up the rear of the engine to the ICM. Two wires are coiled around each other. They sometimes lay on the exhaust and get crispy.
