Old 12-30-2008, 11:07 AM
glennxx1 glennxx1 is offline
bleeding the cooling system
i changed the water pump and the thermostat so im thinking it has a lot of air in the system now, i did some searches on the forum and one said you could just warm the car up and leave the cap off (which is what i was doing earlier sense i saw a lot of air coming into the reservoir
is this an ok way to do it?
my radiator was still ice cold, and my air was still blowing cold (had it on heat full blast) when the car was at normal operating temperature (when i shut it off)
Old 12-30-2008, 02:46 PM
peachesskc peachesskc is offline
Re: bleeding the cooling system
My cavalier will blow cold air when it is on heat if it doesnt have enough antifreeze in it. You might try adding antifreeze or checking to make sure you have the right amount in it.
Old 12-30-2008, 07:51 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
yes, leaving the cap off is an ok way to bleed the system.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
