Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 12-30-2008, 12:19 AM
kevinwylder kevinwylder is offline
98 mercury mystique
i changed my transmission in my 98 mystique and i test drove it fine and then the next morning it started having a few problems like it wont come out of PARK and turn indicator's wont work back up lights wont come on when i over rid it out of park and the heater blower wont work and i checked all of the fuses and relays and of them are good and now i am stumped
Old 12-30-2008, 01:02 AM
discnik discnik is offline
Re: 98 mercury mystique
As far as your blower motor, check your resistor in the heater ducting under the passenger side dash. Should be a four wire connector. Your back-up lights get their power from the selector switch on the transmission. Check the connectors to insure that they are clean and free of debri and no wires have come loose or broken. I'm afraid as far as the turn signals go I have'nt a clue short of doing voltage test from the combination switch out.
Since you just replaced the tranny re-check all wiring harnesses and grounds, if any were re-moved or unplugged.
Old 12-30-2008, 01:15 AM
yeah the turn signals i dont know like the flashers work thats what bugs me i will check the wires under the dash no wires that i know of have come lose or broke but i will look over again do u know why it might not want to engage out of park?
Old 12-30-2008, 01:22 AM
On the Mystique I am not sure how the system to release the shift lever works. You do have to step on the brake in order to shift the lever into gear ? If so there should be a switch to release the locking safety pin. I will see if I can find a schematic on this.
Old 12-30-2008, 01:25 AM
yeah you do have to put the break on and in my Haynes book and owner man. tells u how to override so i did thats how i know my back up light dont work
Old 12-30-2008, 01:43 AM
If you have a manual see if there is a wiring diagram on the lock-out switch for the shift lever. Also how did you check the back-up lights ?
Old 12-30-2008, 01:54 AM
i did a a shift override i had to put a screwdriver in a square opening and turn then it would free up the shifter but still had to press the break that is how i checked the back up lights
