Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-29-2008, 08:36 PM
vica vica is offline
service engine soon light
Hi All,
My 2005 Bonneville's service engine soon light is on. I think my wife left the gas cap loose when she filled the tank. What is the best process to use to get the light off if this is indeed the problem?
Thanks,
Vic
Old 12-29-2008, 09:00 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: service engine soon light
Take it to Advanced or Auto Zone and have it scanned. Write down the DTC's & post back. BTW, tell them to delete the DTC's if they will. If it was only a loose gas cap, you should have no further problems.
Old 12-31-2008, 11:15 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Also, if it was simple a loose gas cap causing the "gas cap" code causing the SES/CEL light it will probably clear after a few drive cycles or when the PCM module tests the evaporative emissions system providing the loose gas cap was the real issue.
Timeslip 08/12/06
AF Community Guidelines
Old 01-03-2009, 01:37 PM
Thanks for the inputs. The problem turned out to be a bad gas cap.
