Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-29-2008, 08:05 PM
ISX ISX is offline
How to disable 1996 traction control?
I got a 1996 marquis and i am sick of this traction control.. HOW do i turn it off!
Old 12-30-2008, 06:01 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: How to disable 1996 traction control?
I am not sure if there is anything you can do to disable just the traction control portion. Maybe a PCM re-program or replacement with one that does not have traction control.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 12-30-2008, 09:14 PM
Scrapper Scrapper is offline
AF Premium User
check your fuses inside of car and under hood i believe theres a fuse you can pull. i had this happen on a guys car little older than yours but at that time they was in glove box. a good alignment man should be able to do it for you if he's good.
Old 01-01-2009, 11:31 AM
Psman32@af Psman32@af is offline
Send a message via AIM to Psman32@af Send a message via Yahoo to Psman32@af
I know in the new Marquis, you can not disable traction control through the PCM. Like it was said above, I would check your fuses.
2005 Mercury Grand Marquis. 230 WHP 249 ft-lbs as measured by a mustang dyno.
