Old 12-29-2008, 05:48 PM
marknoftall marknoftall is offline
Question Transmission Leak
Where does the transmission typically leak on the Windstar?
Old 12-29-2008, 06:27 PM
Scrapper Scrapper is offline
AF Premium User
Re: Transmission Leak
how many miles you got on it? and they can leak at the seal witch you have to pull tranny or your pan seal,tranny lines,or axle seals on tranny. take and clean it off and put a peice of card board and lay under it while it's setting and see where leak is on that card board the next day... good luck....
Old 12-29-2008, 06:36 PM
garync1 garync1 is offline
Is it leaking all the time or just every now and again... If its every now and again it may be coming from the vent tube.. Mine use to do it when it got hot added a cooler on it and it stopped leaking. But i never was comfortable with it being reliable afterward so I had it replace last month.. Plus I had other minor issues that lead to the replacement.. Other place it might leak would be the seal area like mentioned above..
Just when you think you are done. Your not!! Clean the tools. Then you are done.
Nothing impresses a single mom better than a single dad who drives a minivan.Just kidding
