Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-29-2008, 03:12 PM
JimmyC15 JimmyC15 is offline
Please READ NEVER HAD THIS PROBLEM OR HEARD OF IT 96 Jeep GC
Ok my jeep runs fine most of the time but here recently while im drive above 40 on the highway my jeep begins to shake irraticaly so bad sometimes I have to pull over. But it is wierd because it only happen maybe 50 percent of the time i drive. Sometimes I can get in it and drive across town with no problem, thne sometime I get in it and make it a mile and the front end stars shaking, it basically feels like the front end is about to fall out. I am about to crawl under it and check it out. I was thinkin maybe it is a tie rod or maybe the u joint. but when it happens I can feel every shake in the steering wheel. Any advice or even possibilities would be appreciated. Thanks
Old 12-29-2008, 10:44 PM
hundahunta hundahunta is offline
Re: Please READ NEVER HAD THIS PROBLEM OR HEARD OF IT 96 Jeep GC
steering damper, loose lug nuts??
Old 12-30-2008, 12:39 AM
discnik discnik is offline
In this forum go to the "search" and enter"STEERING VIBRATION",you will receive and immense amount of variables.
Old 12-30-2008, 05:50 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Search for DEATH WOBBLE.
There are many things that can cause death wobble: Bad Shocks, Steering Damper, Alignment, Bad Wheel Bearings, or the combination of all.
I had this problem and changed everything in the front end except for the springs and never got rid of it, then I bought a HEAVY DUTY steeing damper (I recommend Old Man Emu SS Damper) and that finally took care of the problem.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
