Old 12-29-2008, 12:54 PM
AbelMagwich AbelMagwich is offline
Where do I get info on engine rebuild/replace options?
I've got a '92 xFi with 175K on the odometer. The 997cc screamer.
I'm thinking about replacing the engine. RockAuto has a remanufactured, warrantied Long Block for about 1,500 -- everything's rebuilt, just bolt on the starter, alternator, and all that.
I know I've seen camshaft kits and other goodies, somewhere, if I wanted to go the custom rebuild route, to go for a little more volumetric efficiency.
When I type JDM engine into google, I do come up with options, there -- I just haven't found any Suzuki 3 cylinders for sale.
I'd appreciate any suggestions anyone might have. I'm going to be getting some money to spend on this in about a month...
Old 12-29-2008, 01:41 PM
livid4fish livid4fish is offline
Re: Where do I get info on engine rebuild/replace options?
Hello and welcome,
Dr. Bill did a wonderful post on rebuilding the little three banger. I don't know your mechanical level, but it is easy to do yourself. On the Rock Auto Engine can you be assured that you are getting a true XFI engine? (Two Piston Ring Grooves, instead of three). Different cam in head for economy. I just rebuilt my 92 XFI myself and it was fun. New rings, rod and main-bearings,oil pump seals the whole she bangy. With a new clutch kit, flywheel and a new head for 850.00. You can take your head to a machine shop get it reworked with stainless steel exhaust valves, price depends on how much is needed to rebuild the head you should be able to get her done for 250.00 or less. Myself I purchased a head from a machine shop delivered to my house ready to go for 180.00, but I had to use my cam out of my XFI head because all he had where base model heads. Still one heck of a deal. If you can do it yourself, go for it.That way you know for sure what you have. I will point out that Dr. Bill did his motor while it was still in the car, if you can and have access to a garage with an engine stand its far easier to pull the motor, put her on a stand, get comfy have plenty of sandwich bags to label and keep parts seperated, clean the parts as you go and enjoy your project.
Hope this helps.......Good Luck!
Old 12-29-2008, 03:15 PM
RossT RossT is offline
Watch ebay, I bought a ac delco reman long block for about $800 shipped. Couldn't be happier. I have also done a JDM, but comparing the two, I prefer the going for the reman over the JDM.
Old 12-29-2008, 06:15 PM
bigsmellyman's Avatar
bigsmellyman bigsmellyman is offline
MI Suzukis didn't have a three cylinder. It was a 1.3 or a 1.3DOHC
Old 12-29-2008, 06:17 PM
Sorry MII 1989-1994
Old 12-30-2008, 12:37 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
OK, then....since Livid4Fish mentioned my threads...I'll be obnoxiously self congratulating and
egocentric and show the threads you mentioned....IN RED
No need to do one of those nasty "Search" things to try to find it....
Most all of my good Automotive Forum Threads with Inclusive Dates…
Maybe these Threads with the answers posted will help someone in need….
1993 Geo Metro Earliest to latest….
“ Motor Oil weights - meaning of numbers?” 11/8-9/05
http://www.automotiveforums.com/vbul...d.php?t=480117
“Front Wheel Bearing - Which side from the sound?” 10/21 to 10/29 /05
http://www.automotiveforums.com/vbul...d.php?t=472753
“Some pictures of our two Geo's” 9/19/05
http://www.automotiveforums.com/vbul...d.php?t=459559
“Exploded Diagram of Geo Metro Throttle Body Anywhere?” 11/11 to 11/13 /05
http://www.automotiveforums.com/vbul...d.php?t=481240
“ '93 Metro 5 spd Transmission - fill where?” 11/13 to 11/20 /05
http://www.automotiveforums.com/vbul...d.php?t=482005
“ Would a '91 engine fit into a '93 Metro ??” 11/20 to 11/23 /05
http://www.automotiveforums.com/vbul...d.php?t=484590
”Is removing the one TB Fuel Injector difficult?” 11/15 to 12/09 /05
http://www.automotiveforums.com/vbul...d.php?t=492475
“'93 Metro running bad of a sudden!” 12/07 to 12/10 /05
http://www.automotiveforums.com/vbul...d.php?t=491454
“ Testing Fuel Pump Pressure - HOW? WHERE?” 12/24 to 12/30 /05
http://www.automotiveforums.com/vbul...d.php?t=497799
“How can you test continuity with an ECM and O2 Sensor?” 12/14/05 - 7/17/06
http://www.automotiveforums.com/vbul...d.php?t=494245
“FYI - For those who haven't seen an ECM” 12/30/05 to 1/29/06
http://www.automotiveforums.com/vbul...d.php?t=499895
“Please help identify these goodies....” 12/31/05 to 1/1/06
http://www.automotiveforums.com/vbulletin/t500271.html
“Identifying Sensors - 1993 Geo Metro 3 cyl TBI 5 speed” 1/2 to 1/6 /06
http://www.automotiveforums.com/vbul...d.php?t=500640
“ Took TB off - Checked Sensors - Partial Results” 1/8 to 1/13 /06
http://www.automotiveforums.com/vbul...d.php?t=503299
“ Taking the Throttle Body Apart - Lower half.” 1/14 – 15 /06
http://www.automotiveforums.com/vbul...d.php?t=505661
“Has anyone ever installed a ROBERK wiper delay?” 1/20 – 22 /06
http://www.automotiveforums.com/vbul...d.php?t=508667
“A very good investment indeed!!!!” 1/19 to 1/21 /06
http://www.automotiveforums.com/vbul...d.php?t=507445
“Bottom Half of Throttle Body Exposed !” 1/22 - 7/12 /06
http://www.automotiveforums.com/vbul...d.php?t=510837
” Applying something learned on this Forum....” 2/28 to 3/1 /06
http://www.automotiveforums.com/vbul...d.php?t=529888
“Cutting and using new gaskets” 1/27 – 28 /06
http://www.automotiveforums.com/vbul...d.php?t=513607
“Would it hurt anything to remove the AC Pump?” 5/14/06
http://www.automotiveforums.com/vbul...d.php?t=565449
“ Lets get this bugger back to working!” 5/14 – 16 /06
http://www.automotiveforums.com/vbul...d.php?t=565402
“That's the end of my '93 Metro.....” 8/2 to 8/31 /06
http://www.automotiveforums.com/vbul...d.php?t=611713
“Reassembling the TBI and getting it running again.” 8/21 - 26 /06
http://www.automotiveforums.com/vbul...d.php?t=609129
“NOT the end of my '93 metro...Life after death! RINGS” 8/30/06 - 4/2/08
http://www.automotiveforums.com/vbul...d.php?t=613410
“How do you clean the Carbon out of the Intake Manifold Gallery?” 9/13 20 /06
http://www.automotiveforums.com/vbul...d.php?t=619189
“How does oil get thru all those bearings?” 9/17 – 18 /06
http://www.automotiveforums.com/vbul...d.php?t=620452
“A way to Clean the Carbon out of the IM Passageways !” 9/22/06 - 7/6/08
http://www.automotiveforums.com/vbul...d.php?t=622536
“Setting up the Timing Belt & Distributor” 10/7 - 10 /06
http://www.automotiveforums.com/vbul...d.php?t=629081
“How does the older 3 Cyl Metro advance the spark?” 10/6 – 7 /06
http://www.automotiveforums.com/vbul...d.php?t=628706
“What happened with Platinum Spark Plugs? Quadrupled in price!” 9/30 – 10/2 /06
http://www.automotiveforums.com/vbul...d.php?t=625854
“Spark Plug Poll - For and Against Bosch platinum Plugs” 10/2 to 10/25 /06
http://www.automotiveforums.com/vbul...d.php?t=627052
“A discussion of engine function.” 9/3 to 10/23 /06
http://www.automotiveforums.com/vbul...d.php?t=615150
“The Flight of the PHOENIX !” Huge 11/18/06 - 3/9/08
http://www.automotiveforums.com/vbul...d.php?t=645309
“Can a 4,6,8 cylinder Tachometer be set for a 3 cylinder?” 11/25 to 28 /06
http://www.automotiveforums.com/vbul...d.php?t=647626
“Oil Level - How Important Keeping It at Top Mark?” 11/21 to 25 /06
http://www.automotiveforums.com/vbul...d.php?t=646376
“Seat Belt Return Springs” 11/4 to 7 /06
http://www.automotiveforums.com/vbul...d.php?t=640299
“Anyone have a '93 Metro 3 cyl Fuse Box Map?” 12/18 to 22 /06
http://www.automotiveforums.com/vbul...d.php?t=655284
“Question about Clutches” 12/9 – 10 /06
http://www.automotiveforums.com/vbul...d.php?t=652609
“Does anyone KNOW which Oil Filter is best?” 12/3 - 7 /06
http://www.automotiveforums.com/vbul...d.php?t=650625
“What Pressure Should Be Run In Tires (Nitrogen?)” 12/3 - 5 /06
http://www.automotiveforums.com/vbul...d.php?t=650617
“ Manual Transmission - Clutch Bolt Fill Hole” 12/30-1 /06
http://www.automotiveforums.com/vbul...d.php?t=658159
“ HELP ! What are symtoms of valve (head) problems?” 11/5/05 - 12/30/06
http://www.automotiveforums.com/vbul...d.php?t=478831
“'93 Metro 5 spd manual oil level” 2/6 - 12 /07
http://www.automotiveforums.com/vbul...d.php?t=671344
“Wal-Mart's 5W-30 Motor Oil” 1/21 - 2/04 /07
http://www.automotiveforums.com/vbul...d.php?t=665491
“ Warning System - Lights On - '93 Geo Metro?” 1/4 - 29 /07
http://www.automotiveforums.com/vbul...d.php?t=659610
“I'm Baaack.... Got off my dead butt! Timing Cover. WITH PICTURES!”
5-14/06 to 1/28/07
http://www.automotiveforums.com/vbul...d.php?t=565338
“Please Educationalize me on Clutches...” 2/13 - 14 /07
http://www.automotiveforums.com/vbul...d.php?t=673781
” This is what happens when you get to liking a car...” 2/ 20 to 4/8 /07 2 pages
http://www.automotiveforums.com/vbul...d.php?t=676351
“ '93 Metro Broken Door Handle Lever” 3/28 - 10/22 /07
http://www.automotiveforums.com/vbul...d.php?t=688316
“What is the miles per gallon difference 3 cyl to 4 cyl ?” 4/7 – 8 /07
http://www.automotiveforums.com/vbul...d.php?t=691384
“Here's a GOOD reason to keep your clutch adjusted correctly!” 3/26/07
http://www.automotiveforums.com/vbul...d.php?t=687590
“The Wal-Mart tire controversy (?)” 5/2 - 17 /07
http://www.automotiveforums.com/vbul...d.php?t=700410
“I tend to exceed the speed limit....” 5/13/07 - 3/9/08
http://www.automotiveforums.com/vbul...d.php?t=704370
“Engine Block - Transmission opportunity” 6/22 - 24 /07
http://www.automotiveforums.com/vbul...d.php?t=718782
“Now I have a Tachometer in The Phoenix...!” 6/17 - 22 /07
http://www.automotiveforums.com/vbul...d.php?t=717109
“Fixing the clutch yourself? Parts source?” 6/11 - 14 /07
http://www.automotiveforums.com/vbul...d.php?t=714691
“ Resonator - Is it important?” 2/20 - 7/6 /07
http://www.automotiveforums.com/vbul...d.php?t=676168
“Vacuum problem - Car works great! Crazy!” 6/27 - 7/3 /07
http://www.automotiveforums.com/vbul...d.php?t=720753
“The Theory of WARMING UP the engine upon startup.” 8/19 - 20 /07
http://www.automotiveforums.com/vbul...d.php?t=741110
“Making a Cell Phone Charger Plug - Always On” 8/11 - 16 /07
http://www.automotiveforums.com/vbul...d.php?t=738114
“Poll - What is your Metro's Gas Mileage?” 8/24/07 to now ONGOING!
http://www.automotiveforums.com/vbul...d.php?t=410550
“Valve Burning - any way to know before disaster strikes?” 9/16/07 - 3/24/08
http://www.automotiveforums.com/vbul...d.php?t=751546
“The error in determining Miles/Gallon....” 9/23 - 28 /07
http://www.automotiveforums.com/vbul...d.php?t=753935
“Is there a "Trick" to adjusting the Window Regulator?” 9/17 - 18 /07
http://www.automotiveforums.com/vbul...d.php?t=752044
“ Any POWER CURVE (rpm vs torque) published for the 3 cylinder Suzuki engine?”
9/13 - 17 /07
http://www.automotiveforums.com/vbul...d.php?t=750629
“ Why do my miles/gallon fall off in Winter?” 10/12 - 26 /07
http://www.automotiveforums.com/vbul...d.php?t=758786
“Ring Replacement.. Doc you SOB!!!!” 10/18 – 19 /07 Not My POST !
http://www.automotiveforums.com/vbul...d.php?t=759926
“ Have any metros hit a deer?” 6/9 - 11/27 /07
http://www.automotiveforums.com/vbul...d.php?t=721485
“Power vs Altitude and Cold Air” 12/18 - 24 /07
http://www.automotiveforums.com/vbul...d.php?t=772048
“ What is turning in the Transmission at idle, clutch out?” 12/13 - 17 /07
http://www.automotiveforums.com/vbul...d.php?t=771249
“ Tires - Nitrogen versus Air” 11/20 - 12/08 /07
http://www.automotiveforums.com/vbul...d.php?t=646100
“How difficult is it to replace Transmission's Bearings?” 1/9 - 10 /08
http://www.automotiveforums.com/vbul...d.php?t=880245
“ Question about the AudioVox Cruise Control” 1/6 - 8 /07
http://www.automotiveforums.com/vbul...d.php?t=879443
“My heater fan quit working - 20 °F !!!” 1/11 - 19 /07
http://www.automotiveforums.com/vbul...d.php?t=880868
“Automatic Door Locking” 6/15/05 to 1/9/08 Ongoing?
http://www.automotiveforums.com/vbul...d.php?t=420547
“ Why Is It That...?” 1/11 - 2/21 /08
http://www.automotiveforums.com/vbul...d.php?t=880935
“Spark Plug Gaps - Regular vs Platinum” 4/6 - 6/10 /08
http://www.automotiveforums.com/vbul...d.php?t=897540
“Does it do ANY good to use STP (Oil Additives) ?” 4/25 - 28 /08
http://www.automotiveforums.com/vbul...d.php?t=901299
“ Alternator noise” 4/25 - 27 /08
http://www.automotiveforums.com/vbul...d.php?t=901305
“The way Metros Die - rust out in the control arm / underbody area (PHOTOS)”
4/28 - 5/17 /08
http://www.automotiveforums.com/vbul...d.php?t=901676
“Getting Vehicle Warrentee Offers - Garbage?” 5/6/08
http://www.automotiveforums.com/vbul...d.php?t=902836
“ Could a 3 Cylinder Metro be made to run on Ethanol?” 5/9 - 7/13 /08
http://www.automotiveforums.com/vbul...d.php?t=903337
“Odd & Assorted Questions for Metroglodites” 5/29 - 6/2 /08
http://www.automotiveforums.com/vbul...d.php?t=905936
“Any 5 speed Transmission rebuilds with pictures available?” 6/15 - 16 /08
http://www.automotiveforums.com/vbul...d.php?t=908274
“Struts and Strut Bearings (?)” 7/10 - 13 /08
http://www.automotiveforums.com/vbul...d.php?t=912279
1990 Jeep Cherokee
“How hard is it.....?” 2/4 to 2/5 /08 Injectors
http://www.automotiveforums.com/vbulletin/t886812.html
Old 01-10-2009, 12:47 PM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
I rebuilt mine and it's running great still. I now have 20,000 miles on it and crankin right along. I prefere that method, as apposed to buying JDM, because then you'll know what you have and you'll know what kind of oil it'll have running in it from day one. Sure, most of them work out great, but remanufacturing it, I think is better and a bit less than 800 bucks.
I think I have about 800 for remanufacturing the engine, plus a JDM tranny.
