Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 12-28-2008, 10:27 PM
concepra concepra is offline
Send a message via Yahoo to concepra
Oil Leak
Oil in cavity where spark-plugs is located. I removed valve cover now what?
Old 12-29-2008, 11:26 AM
denisond3 denisond3 is offline
Re: Oil Leak
Oil that is on the upper end of the spark plugs is not a problem I would bother to fix. Its just a sign that the tubes the plugs fit down into are no longer sealed from the oil inside the camcover - due to the rubbers seals at the bottom of the tube getting old and hardened from the heat.
With the cam cover off though, you can put new rubber seals on the bottoms of those tubes. The seals probably come with a new cam cover gasket, or can be bought at any decent auto parts place.
Not having done it myself, I think you just pull the tubes straight out.
Old 12-29-2008, 08:18 PM
Chris Maynard Chris Maynard is offline
Re: Oil Leak
If oil is leaking behind valve cover near the headers, its the oil pressure sending unit.
Thats an easy fix and i hope that is your problem.
Old 12-29-2008, 08:32 PM
Scrapper Scrapper is offline
AF Premium User
Exclamation Re: Oil Leak
you need to replace valve stim seals sounds like to me if there is oil on the outside of the plugs. you have to have air to hold up the valve while replacing them. if you don't know what your doing you should get a mccanic that know's what there doing or you can run into big problems. so if you know a mccanic friend see if he can help you. or get a haynes manul and it will walk you threw it....good luck...
Old 12-29-2008, 08:34 PM
AF Premium User
Re: Oil Leak
you might want to check oil sending unit but that wont make it get oil on the outside of the plugs.
Old 12-29-2008, 10:38 PM
hundahunta hundahunta is offline
Re: Oil Leak
easy fix, replace the spark plug tube seals, and valve cover gasket.. don't forget to apply engine sealant on the corners or all places there are points
