Go Back   Automotive Forums Car Chat > Buick > Regal
Old 12-28-2008, 11:05 PM
mt_100 mt_100 is offline
Tight Caliper Bracket Bolts
Was going to change the rotors on my 92 Regal this weekend since it was 55 degrees here in MI and I couldn't for the life of me get the two caliper bracket bolts loose.
I can get the caliper off the bracket but there are two bolts that hold the bracket on the hub assembly, torx T-60 heads on them, and they will not budge. Without getting that bracket off I can't get the rotors off.
How do mechanics do it? I tried a breaker bar, Bolt Buster, hitting the breaker bar with a hammer, no go, not even a budge. Air tools?
Also, how do I push in the emergency break on rear wheels? I know how to squeeze a caliper in, but it seems it won't go in all the way on the passenger side for the thicker rotor. Drivers side wasn't an issue since the previous owner cut the E-brake cable.
Any help would be appreciated.
Old 12-31-2008, 11:59 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Tight Caliper Bracket Bolts
The T-60 torx headed bracket mounting bolts need to be heated. They have factory applied threadlock on them and are virtually impossible to remove without heating with a small propane torch.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
