Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 12-28-2008, 09:18 PM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
2001 CRV CEL flashing with no codes
I have a 01 crv 4wd EX with a CEL that flashing with no codes i did a tune up adjusted the valves to exact specs.... checked timming changed the plugs wires cap and rotor (all with honda factory parts) and still get a flashing mil... i have a snapon MT2500 and everyonce in a while i get P0304 (miss on #4) but when i cycle the ignition it goes away and then after running for about 20sec it starts flashing the CEL but no codes will be present! my trouble shooter says that if the code doesnt come back ... the ECU has failed can anyone shed some light or have any other ideas???
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 12-31-2008, 10:49 PM
Re: 2001 CRV CEL flashing with no codes
i unhooked the battery for 1min and test drove it and it went away runs like a screaming ape
Old 12-31-2008, 11:49 PM
kris's Avatar
kris kris is offline
Off playing with fire.
I usually find that unhooking the battery helps a lot of small issues I cannot seem to answer.
Easy fix by the sounds of it.
