Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 12-28-2008, 02:27 PM
lcc lcc is offline
gas mileage has dropped...2004 Envoy XL 6 cyl
My 2004 Envoy has about 80,000 miles on it. It runs fine, but recently gas mileage has dropped severely. What should I check first, besides the obvious? I change the oil every 3,000, and it uses no oil. Air filter is clean and relatively new. I haven't checked plugs yet, but isn't this allegedly a 100,000 mile tune up car? I know the plugs, wires, etc. are a first place to check, but has anyone had a similar problem? Is there a particular thing that is known to happen to these things at this mileage?
Old 12-28-2008, 07:18 PM
maxwedge maxwedge is offline
A990 racer
Re: gas mileage has dropped...2004 Envoy XL 6 cyl
Welcome to AF. Me too, cold weather has knocked off 2 mpg. here in the NE. Get it scanned and look at o2 sensor activity for starters. Use of awd or 4wd has the same effect also
Old 12-29-2008, 09:44 PM
lcc lcc is offline
Thanks for the reply...quick question....if I have someone hook up the scanner will it tell the 'history' of O2 sensor activity, or will it only indicate if there is a problem at that moment? Wouldn't O2 sensor give a Check Engine message?
Old 12-30-2008, 09:07 AM
A990 racer
The 02 could be " lazy" and not set a code.
Old 01-09-2009, 03:51 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I noticed a drop in fuel economy and found that the flange bolts between the exhaust manifold and the cat were loose, resulting in an exhaust leak. Once I tightened those back up, mileage returned. Open the hood and listen for a leak on the passenger side of the block.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
