Old 12-28-2008, 09:54 AM
99silveradols 99silveradols is offline
99 Silverado - OBD-2?
My 99 SES light came on out of the blue and I need to learn the code. In the old days (OBD-1?) you could short out 2 pins on the port and the SESlight would flash the numbers for the error codes. I had a 87 Transam and this worked perfectly.
First, is the 99 OBD-2? And is there a way to do this little trick with this system? Or does a guy need to buy a reader?
Thanx
Old 12-28-2008, 03:18 PM
j cAT j cAT is offline
Re: 99 Silverado - OBD-2?
Thanx
YOU need a scanner or go to auto zone and they will give you the DTC...then post back what the code is...
Old 12-28-2008, 10:15 PM
Thanks. I went and picked up a scanner (no Autozone in Canada). It came back with P0785. I had this code once before and GM said it was a defective ignition lock. They replaced the ignition cylinder at it has been fine for a year.
I get the idea it may be caused by something in the remote start. I guess I'll see what happens - I cleared the code for now.
Old 12-29-2008, 09:14 PM
po 785 is a transmission dtc...this could be the electrical connector at transmission ,solenoid problem,metal debris blocking the fluid flow,,etc....
that b/s from dealer was a scam....
Old 12-30-2008, 08:51 AM
Well, whatever. They said that the problem was in the ignition cylinder and was causing an intermittent "communication" failure between the ignition and the 4x4. True or not I don't know. I suspect you're right though - they just erased the code and it hasn't surfaced since.
A little research about P0785 (timing solenoid is what it calls out) shows that it could be any number of things that cause that code. So, like almost every code I have experienced in the past (1987 Transam) there are a dozen things that can trigger it. Very frustrating.
We'll see if it comes back.
Old 12-30-2008, 09:37 AM
check the transmission conector.....this is quick...if you bought this used and you do not work on your vehicle it is very possible it was not installed correctly....
Old 12-30-2008, 10:53 AM
I did buy it used 3 1/2 years ago. It only has 105000kms (65000 miles). I haven't ever done any work around the tranny. I assume on these models there is just the one electrical connector? Is it on the drivers side like the old 700R4s?
Thanks
Old 12-30-2008, 01:02 PM
Thanks
yes driverside , follow the wires...
