Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-27-2008, 08:07 PM
priestkyl priestkyl is offline
low end (torque)
hey i have a 1992 eagle talon tsi AWD. I just wanted to know if anyone could tell me how to get more low end out of my car. i have a T2 turbo on it and an exhaust (no headers yet). I have alot of power when i get to about 2500-3000 RPMs and its an automatic so i always get slautered on the launch but i think it has alot of patential. i would rather not dump alot of money into it YET. any cheap solutions?? also the moter is a stock 2.0 how much boost do you think i should be putting to it ? i really cant afford to blow the thing up. and i put a boost controler on it so its getting about 14lbs right now.
Old 12-28-2008, 11:14 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: low end (torque)
Welcome to AF!
First things first do your maintanence stuff: plugs, wires, fuel filter, timing belt if you need it.
You have what turbo on it? Uh never heard of a T2 before. The car came stock with the 13g turbo on it so is it stock? There no "headers" on your car either, its a manifold and if its still stock then you have either the stock turbo or a 14b, 16g, possible a T25 but that would be stupid to put on the car as its so small.
Your car is not going to have much torque down low because its turbo and you have a low compression motor out of boost. So your just going to have to deal with that. As far as getting off the line hold the brakes and give the car as much gas till the car starts to pull forward. Let off the brakes and floor it to get the best launch.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-29-2008, 09:56 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
In addition to the above, "about" 14lbs is a scary thought when using a stock boost gauge. Get a real one.
Kris
2012 Genesis Coupe 2.0t
Old 01-02-2009, 02:16 PM
ok so i have to deal with the fact that it does not have a v8. but to my second question are the stock boost gauges inacurate? if they are not and my boost gauge is right is 14 too much for my stock motor? sorry for all the questions but i am new to tuner racing and am used to having to build up a motor (wich in a tuner also looks very funny to me) not a turbo.
Old 01-02-2009, 02:19 PM
Stock gauge is based around a guess the ECU makes then relays to the dash. Get a real vacuum/boost gauge before anything else.
I have no clue what your second sentence is about...
Kris
Old 01-02-2009, 02:48 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
14lbs is fine for the stock motor as long as it's in good shape. But as Lando said, before you did anything ESPECIALLY putting a boost controller on, you should have gotten a boost gauge first. Take off the boost controller, wire everything back to stock and then get a boost gauge. Then do what you want.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-02-2009, 03:35 PM
steviek's Avatar
steviek steviek is offline
stock motor can handle 50lbs/min! but your fuel system can't. there are many more limiting factors than just what the motor can hold.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
