Old 12-27-2008, 10:18 AM
Drew84 Drew84 is offline
My EG Civic Build
I miss my '00 Si and I've always liked civics since then so I picked up the Hasgawa EG hatch kit. I want to do a striped out auto-x/track car styled build. I have to find some scale 15 inch wheels for it. I'm also trying out some Testors "One Coat" Lacquer I found at my Local hobby shop. This looks like what Testors is bringing to the table to compete with Tamiya Sprays. I'm also using this kit to practice building a roll cage and some other minor detail things.
So I started the kit by building the main hoop and this is what I have so far.
After taking some measurements of the interior. I drew out the shape of the main hoop on an old model kit box. So I could use the stiff cardboard as a template.
I erased the guide lines to get close the final shape
Cut out the shape
I cut out the template and test fitted in the interior, some trimming was needed but I was pretty spot on. You can now see the shape I'm going for. The seats are from the Tamiya Celica SSII these will make a nice street/race seat for the civic.
Inside the body checking clearances
Now to make the rollbar I used Evergreen 3/32 diameter tubing, it is very easy to bend and form. I set up a jig with push pins and a piece of plywood. The hair dryer helps a bit to set the final shape. Just be careful not to melt the plastic. I actually found it was easier to make one side and then flip it to make the other side. Not an exact science but I like the result.
I trimmed the rollbar and test fitted. Looks pretty cool I think.
Adding a diagonal bar, I'm going to add a harness bar too.
Finally I opened up the rear cargo cover access panel areas so I can build a strut tower bar and connect down tubes from the rollbar.
Andrew
'05 WRX STi
'90 Talon TSi AwD
'95 Rally Mirage Co-Driver
http://www.flickr.com/photos/drew84/
http://lateralg.blogspot.com/
Old 12-30-2008, 01:31 PM
evil_hanzel evil_hanzel is offline
Re: My EG Build
nice start! be careful of the body's a-pillar as it breaks very easily.
looks like we both think of the same interior concept for the EG:
http://scaledricers.blogspot.com/
http://evil-hanzel.deviantart.com
WIPs:
TE27 levin
Old 12-30-2008, 01:36 PM
Re: My EG Build
here's my EG thread.
http://www.automotiveforums.com/vbul...81#post5692981
WIPs:
TE27 levin
Old 12-30-2008, 02:10 PM
Re: My EG Build
Yeah I noticed the a pillars are very thin. Yeah I like that interior, I think I saw that when I was searching Civic WIP threads.
Andrew
'05 WRX STi
'90 Talon TSi AwD
Old 12-30-2008, 09:55 PM
Re: My EG Build
Ok, worked on the cage some more tonight and finished it. I added a rear strut /tie bar and down tubes. Also I added a harness bar. I'm really happy with the way it looks.
I started by making some triangles out of Evergreen square stock. Hard to see in the picture.
I then connected the to pieces with some round stock.
Now it needs a harness bar, this shows half of it done
Down tubes, cross bar installed and connected to the strut bar.
I am super happy with the way this looks, now its time to start painting.
Andrew
'05 WRX STi
'90 Talon TSi AwD
Old 12-30-2008, 10:09 PM
AustinMartin's Avatar
AustinMartin AustinMartin is offline
Re: My EG Build
Wow!
Current Builds
Ferrari Enzo
Ferrari 612
Ferrari F2007
Ferrari 250 Testarossa
"Speed never killed anyone, it the stopping suddenly that kills you"
"With every post they take off me........they take a piece of my heart" PAP 348
