Old 12-27-2008, 10:01 AM
m74cran m74cran is offline
97 k1500 oil pan removal
how do you take the oil pan off, this is my first 4x4, i have all the bolts off the oil pan, oil filter adapter is off, tork converter cover is loose, looks like the cross over exaust pipe is in the way (don't want to take that off), and front axel looks like that is in the way too, oh and the steel rods that go from the engine to the tork converter housing is loose,do i have to remove the front axel, any help would be great, thank you.
Old 12-27-2008, 10:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 k1500 oil pan removal
You may need to remove the front 3'th member /rear end front.
MT
Old 12-27-2008, 05:20 PM
777stickman 777stickman is offline
Agreed. On my '98 Sub K2500 7.4 the front drive assy had to be dropped in order to get the pan off. A note on that. Remember to disconnect all the wiring up there. ABS, both sides, and front differential lock actuator and anything else. It doesn't have to drop very far to get the pan off.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-30-2008, 06:42 AM
it was alot easyer than i thought,3 bolts, two holding the axle on the right, and the top pumpkin bolt, take these out and the whole axel slides down and to the front, then turn the wheels to the left because the pumpkin rests on the steering rod and that gave it enough to slide the oil pan out, thank you
Old 12-30-2008, 10:21 AM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went.
Yes sometimes not as bad as a 2W drive.
Good luck
MT
