Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-27-2008, 06:59 AM
Cobrargc Cobrargc is offline
Power Window Repair
My son car is an '88 Ciera. Power windows will operate fine from each individual door switch (passenger, rear doors). The master switch is dead. It will not operate any of the four windows. I've checked other threads and concluded a possible broken wire in the hingle area of the drivers door.
1)Would a broken wire in this area still allow the other window switches to work? I'd read another thread suggesting the other three switches being fed from the master switch.
2)What is involved with a wire repair in this area? Is there a connector or plug behind the kick panel, where the PW harness might connect to so I could pull the entire door harness out for inspection? Otherwise it would seem difficult trying to inspect the wires behind the rubber boot in the hingle area.
Thanks in advance
Old 12-31-2008, 12:27 PM
jsgold jsgold is offline
Re: Power Window Repair
On my dad's 89 Cutluss he had to cut the boot to find the problem..which he did. two of his wires were broken, 2 more were almost. Not sure on your situation but all of his were dead at the time.
I used to be indecisive, now I am not so sure.
Old 01-02-2009, 12:33 AM
JohnDD JohnDD is offline
On my 91 Cutlass Ciera, I just pulled the boot out of the door/ post and repaired the broken wires. Then pushed the boot back into place. Pulled on the wires to locate the ones that were broken. Good luck!
Old 01-02-2009, 04:47 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF Cobrargc !!
You can pop out the master switch and check for power. If everythings dead I would bet the wires are broken in the jam area inside the boot.
It is pretty easy to pull the boot back and check without cutting the boot. That might allow water to drain inside the cabin area.
Those little wire but connectors work well for repairing damaged wires.
1999 Grand Am SS 3.4 OHV
Old 01-02-2009, 05:23 PM
Hey thanks for the info. It did turn out to be 2 broken wires inside the rubber boot. It is now repaired and working fine.
