Old 12-27-2008, 04:30 AM
ice745 ice745 is offline
AF -Advisor
RCA cabling question
These may be really dumb questions, but I just want to make sure I don't do anything dumb.
I have a 4 channel amp, and a monoblock that accepts 2 inputs. My head-unit has 4 channel preouts and 2 more preouts for the subwoofer channel.
Assuming the 2 sub pre-outs from the head-unit aren't just from an internal y-splitter, and are actually from 2 preamp circuits; I imagine it'd be best to hook these both up to both the sub amp inputs, right? Or does it actually not make a difference?
Now the main question is, how would you run the RCA cables. The two amps are close enough to each other that I can get a 5.1 RCA set; using the front and rear cables for the speaker amp, and using the center and subwoofer cables for the 2 subwoofer inputs. Would this be an acceptable solution? As far as I know an RCA cable is an RCA cable, it doesn't matter what frequency range it's meant for. Or would I have to go with a 4 channel and a 2 channel RCA set?
I already have a 4 channel Stinger set, from when I had a 2 channel speaker amp, and the same sub amp. But that's from when I was sloppy and just threw a system together. Now I'm trying to do it "right."
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
Old 12-27-2008, 08:30 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: RCA cabling question
a wire is a wire, using the 5.1 cable will discourage engine noise because they are all so close together.
Old 01-27-2009, 02:02 AM
parrotscaraudio parrotscaraudio is offline
Send a message via Yahoo to parrotscaraudio
Wink Re: RCA cabling question
Sub out put to sub input
RCA is RCA just match your outputs to your inputs
22 years in car audio instalation
www.rlsnell.20m.com
Please register in our forums
Questions answerd daily
www.autowreck.com.au
http://z3.invisionfree.com/APV/index.php?
http://www.youtube.com/user/parrotscaraudio
