Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 12-26-2008, 08:31 PM
[email protected] burkhs@yahoo.com is offline
need help - trying to remove inner tie rod end
I have a 2000 ford focus. I am trying to change the inner tie rod end, but am having difficult time removing the inner tie rod end where it connects to the steering. There seems to be no way to get a good hold on it. Any suggestions will gladly welcome.
Old 12-27-2008, 11:03 AM
rhandwor rhandwor is offline
Re: need help - trying to remove inner tie rod end
Auto Zone or Advanced should loan or rent a tool this is a picture.
http://www.autopart.com/tools/toolsmain/tool/T_4009.htm
Use a large crescent on the flat of the rack as you can damage it by putting to much pressure on it. You hold it steady as you remove the end.
Some Fords have a lock pin. Use search A470 is a lock pin removal tool.
If you need more sizes 4012 is a larger set of inner tie rod tools.
