Old 12-26-2008, 07:52 PM
indebt94 indebt94 is offline
rear suspension combo questions
so i got a rear disc conversion from the greatest junkyard in the world by me and im not gonna put it on until i have everything i need to complete the rear suspension entirely. since the rear trailing arm is from a 90-93 integra, what should i order the lower control arms for a civic or integra or is there no difference. i have the same question about the rear camber kit, civic or integra? my next question is i run kyb gr2's and regular coilovers. i cant seem to lower the rear to where i want it via the coilovers. i cant get it low enough, whats up?
Old 12-27-2008, 02:54 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: rear suspension combo questions
The DA trailing arms will all match fine. However if you want to replace the bushing in the arm its a diff size than the civic. You can use civic or integra trailing arms but again the bushings are slightly diff size in case you want to replace them.. no diff otherwise, but they do have rear sway bar mounts that unless you get arms from an si, the civic wont. Also the upper links are civic, As for the suspension being low enough.. cant really explain that.. except wtf are "regular coilovers"? Try taking the sleeves off and just running the spring.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 12-29-2008, 02:08 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
as well jsut to add to frodo's statement. the upper control arms from the civic vs those da teg parts well there no difference at all i went from civic to teg part becasue i read some were that there slightly longer but its jsut a myth. and really if u wanna get it "low" or in the right spot as u put it try a full coilover suspension.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
