Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-26-2008, 01:02 PM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
Exclamation '99 Ram Diesel throwing oil
My wifes '99 Ram 2500 w/ Cummins 24 valve is dropping oil from the area around or from the crankcase vent tube (right side forward on engine). This is increasing in quantity daily, and started about a week or 2 ago. Any ideas would be appreciated!
Hope you had a Merry Christmas!
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Old 12-28-2008, 03:22 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: '99 Ram Diesel throwing oil
Sounds like you lost yer puke bottle.
There's a plastic "puke" bottle the vent tube sticks into in that area. It catches oil droplets in the blow-by gasses. You drain the bottle every time the oil is changed.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 12-28-2008, 09:43 PM
Thanks for the tip, Chris, but I think this is more serious. I don't recall ever seeing a puke bottle on either of my 2 Dodge diesels, and this one wasn't dropping anything about 6-8 weeks ago. A pro trucker friend thinks I may have some sort of crankcase ventilation blockage issue.
I will put something on the tube to see for sure how much is going out.
Stale Trooper
'05 CVPI
