Old 12-26-2008, 10:19 AM
Sixx Sixx is offline
Swirl marks after polishing?
I'm in somewhat baffled by a recent experience with polishing. I'd like to think I had the whole polishing concept down, I've done it numerous times with several different mediums.
Here are the players:
Hiroboys Finishing Compounds; Coarse, Medium & Fine
Tamiyas: Coarse, Medium & Fine
3M polishing compound
Novus: Step 1, 2 & 3
Tamiya Wax
Carnuba Wax
Micro fiber cloths
The car has been sprayed a urethane base coat, topped with a urethane clear coat that's had micro flake added to it. Dried, wet-sanded, dried and cleared with Dupont Clear. Everything was going well up until this point. The car was very smooth but I wanted to level out any high spots so I did as usual as began with Hiroboys Coarse compound, then subsequent polishes after that.
When it left faint swirl marks and hazing, I used Tamiyas compounds which too me at less gritty, still swirl marks and hazing.
I waxed her up with Tamiya wax, still hazy with less obvious swirl marks.
I followed that with 3M, then the Novus polishing system......same results
A final coat of Carnuba wax and still the same results..........
The car is smooth and shiny, but there are a few swirl marks and very faint hazing upon very careful inspection.
Due to the final clear not really needing much as far as smoothness is concerned, I'm wondering if I should have skipped the coarse compound for something more mild. I have been very happy with the results using Hasegawas ceramic compound also.
Any suggestions on what might have happened? and a possible answer to how to buff out the final faint swirl marks?
Old 12-26-2008, 04:00 PM
robrex's Avatar
robrex robrex is offline
Re: Swirl marks after polishing?
I've had mixed results with the 2K clear as well after polishing. I think it's because 2 pack paints need to be polished within a certain time period or they get too hard therefore leaving small scratches that, as you have found, are almost impossible to remove. I'd be interested to hear others opinions though.
Rob
