Old 12-25-2008, 08:09 PM
djjm3 djjm3 is offline
2000 BLAZER Ground Strap Question
There is a ground strap that attached to the firewall.....It's turning green...I was wondering- should I replace it or leave it as is?
Old 12-26-2008, 09:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 BLAZER Ground Strap Question
Copper turns green with tarnish.
It should be good.
But a extra ground would not hurt anything.
Always check battery cabel ends for build up on them.
Clean and lubercate if so.
More problems there than anyplace.
Good Luck
MT
Old 12-26-2008, 06:26 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
a quick check for bad grounds is to check for voltage in your coolant. With the engine cold pop the raditor cap and put your positive lead off your voltmeter in the coolant and the other end to a chassis ground with the engine running. any voltage over .03 indicates a ground problem.
