Old 12-25-2008, 02:01 AM
wrightpressman wrightpressman is offline
98 gtp starting problem
My car ran fine the other day, went to start it the next mouring and it wouldn't start but turns over. i replaced the ignition control module and got the same results. i have gas and spark but it still won't start. any help would be much apprieciated
Old 12-25-2008, 02:01 PM
doctorhrdware doctorhrdware is offline
Re: 98 gtp starting problem
Could it be a problem with the crankshaft position sensor? Have you tried starting fluid to see if it would fire, pull a plug to see if it is wet or fouled. I would also see if you can pull any DTC from the car's computer.
Old 12-25-2008, 05:26 PM
wafrederick wafrederick is offline
Banned
Check the fuel pressure,GMs will not run under the specified fuel pressure specs.It could be a bad fuel pump.
Old 12-25-2008, 09:27 PM
jrmy1krn jrmy1krn is offline
I had a similar problem the other day on my 98 GTP... of course it was -5* F here. Couple shots of starting fluid and a can of dry gas did the trick. I love winter time lol. Well I dont know how cold it is where you live but just a thought.
Old 12-27-2008, 04:40 PM
Jrs3800 Jrs3800 is offline
#1 Question...
Does the car have spark?
3800V6's will run under the spec pressure... They will run in the 30's, not very well but they will run..
48-55 Psi is the range you will be looking for..
Old 12-27-2008, 10:20 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
The OP says he has "gas" and "spark". So I assume he's got adequate pressure. I would next check out injector pulses.
How many miles are on this car?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-27-2008, 11:51 PM
That is one thing I forgot, the injectors could have a problem.
Old 12-29-2008, 06:34 PM
billheis billheis is offline
I've got a 99 GTP that wouldn't start. Turned out to be the MAS. Disconnect it and see if it will start. It will run ratty, but if thats the prob it will fire.
