Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-24-2008, 02:24 AM
nashville_rodeo01 nashville_rodeo01 is offline
My smoking 01 rodeo..
I was wondering how i could fix it without taking the entire engine apart...it only does it when i start it and if i get over 40 mph..
Old 12-24-2008, 04:15 AM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
Re: My smoking 01 rodeo..
You're going to have to provide better details.
1. Truck specs
2. Is it white or black smoke?
3. Where is the smoke coming from? Engine bay or exhaust?
4. Any recent maintenance?
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 12-24-2008, 09:45 AM
Ramblin Fever Ramblin Fever is offline
Is it driven much?
Mine will do this upon starting it if I've let it sit for more then a week at a time.
Mine does not do it above 40 though, only when I first start it after sitting a while.
Could be a hundred things, but we need more input: Engine, mileage, year, maintenance, are you the original owner, also, how cold is your climate.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 12-25-2008, 12:19 AM
Sorry it is a 2001, the v6 3.2 motor,4x4, just about to roll over to 92,000 miles, regular maintenance to factory specs, i live in Nashville TN so it gets up to 110 in the summer and as low as 5-10 degrees in winter, but it smokes in all weather,and it is a white kinda gray smoke, the end of my tail pipe is covered in a lot of black carbon more than is supposed to be there.
Old 12-25-2008, 01:18 AM
or if i am towing my waverunner,and i have to get on it to get going.
Old 12-25-2008, 01:50 AM
Are you losing any antifreeze?
When have you last changed your spark plugs?
Does your truck use LOTS of oil?
Bluish-gray smoke is generally oil burning, or oil leaking past the rings; whiteish-gray is generally antifreeze leaking into the combustion chamber, IIRC
I wouldn't hope it would be anything major, 92k miles is nothing in comparison to my 188k miles, my engine has never been opened.
Has it ever been allowed to overheat? And, what does the temp gauge normally read at? Wondering if it's getting to normal temp.
1997 3.2L V6 Rodeo
