Old 12-23-2008, 08:46 PM
dirtbikemaniac37 dirtbikemaniac37 is offline
93 chevy 1500 V6
the engine is runnning but cylinder 5 & 6 is missing.
whats the best thing to do? check valves. rings? thanks
Old 12-23-2008, 08:59 PM
tempfixit tempfixit is offline
Re: 93 chevy 1500 V6
When was last tune-up?
Check rotor and distributor cap and wires.
Any codes???
Do compression check.
Check intake for vaccum leak.
Old 12-23-2008, 09:13 PM
i put new plugs and plug wires on it last year. and no compression at all.
Old 12-23-2008, 09:30 PM
no compression on 5 and 6 or all clyinders?
Did you do a wet compression test also? (squirting oil into clyinder to see if rings are bad)
Old 12-23-2008, 10:06 PM
only 5th and 6th cyclinder is missing. and no i have not.
how do I do that test?
Old 12-23-2008, 10:16 PM
Squirt some oil thru the spark plug hole, enough to cover the rings on the piston and do compression test. If you have a increase in compression from the dry test the rings are leaking if not problem is in the valves or intake. I am more inclined to think you have a intake problem.
WHen you say 5th and 6th are you meaning the rear clyinder on the left side and rear clyinder on the right side of engine???
Old 12-23-2008, 10:27 PM
okay. thanks alot
and if there is a intake leak. where would that be?
and what part would possibly need replacement?
Old 12-23-2008, 10:57 PM
okay. thanks alot
Would you explain which clyinders you mean by 5th and 6th??
Driver side clyinders are #1,3,5 (from radiator to firewall)
Passenger side are #2,4,6 (from radiator to firewall)
Old 12-24-2008, 08:47 AM
the 5th cylinder is on the driver side in the far back and the 6th is on the passenger side in the far back
Old 12-24-2008, 01:45 PM
Let us know results of the wet compression test and we will help more from results.
Old 12-24-2008, 03:53 PM
okay. thanks
