Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-23-2008, 05:52 PM
jesselv jesselv is offline
Key won't release from ignition
Can't get the key out after placing car in park on my 2001 Rodeo. Could be related to the switch in the console which releases shifter. I had a problem with that until I discovered that if I pulled back slightly on the shifter before depressing button it would release from park. Any answers as to the cost of having the dealership fix this.
Old 12-23-2008, 09:46 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
Re: Key won't release from ignition
Try calling the stealership?
Several people have had this issue including me. It's an easy fix. If you search my posts you'll find the OP about the issue.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 12-23-2008, 10:55 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
http://isuzufaq.ibctech.ca/#faq78
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 12-23-2008, 11:09 PM
I Teach I Teach is offline
I do not know much about that specific vehicle however a few things to try would include: 1 pull the steering wheel all the way to the left or right and try to remove the key. 2 make sure the shifter is all the way in park especially if you are on a hill. 3 you will look stupid but it has worked for me try rocking the vehicle while attempting to remove the key. Two of a few possible causes may be worn tumblers in the ignition or even a copied key cut bad.
