Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-23-2008, 04:54 PM
trilateral1 trilateral1 is offline
5.2 GC, timing cover hole
Anyone ever have a hole develop in the top of the timing cover on their GC 5.2L? Noticed coolant on the garage floor a couple times over the past couple months, couldn't find a leak. Of course, I was looking in the normal areas you would expect to find such a leak. Then I changed the oil today and was running it afterwards and noticed a nice stream of coolant pouring out on the floor, I was able to see the source this time, the top left of the timing cover appears to have a hole in it. My second question would be, where can one aquire a replacement (used is fine) at a reasonable cost?
Old 12-23-2008, 05:00 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 5.2 GC, timing cover hole
coolant shouldn't be coming out of the timing cover
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 12-23-2008, 05:32 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Are you sure it isn't the water pump? Chrysler's 5.2 water pumps were made to start leaking out of the "weep hole" when the water pump was going bad.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-23-2008, 05:51 PM
I guess I should have said the timing housing.
Old 12-24-2008, 05:29 AM
Could you take a picture and post it?
Old 12-24-2008, 06:23 AM
It won't be until next week that I can take it apart but I will get a pic at that time, hopefully there is a better explanation to this problem when I get it apart. From what I can see, it is coming from the top of the housing on the left side right above the water passage.
Old 12-29-2008, 06:01 PM
mcgee139 mcgee139 is offline
I had the same problem on my 1994 gc I just brought the cover in to a welding shop cost me $20 to have it pached since i was in their i changed the pump and the timming chain and gears at the same time good thing I did the chain was sloppy just a suggestion.
