Old 12-23-2008, 12:14 PM
glennxx1 glennxx1 is offline
96 cavalier water pump
my gf's car just started overheating, i went and met her where she pulled over and the reservoir was empty, so i filled it up, and thought that was the problem, but i then felt the radiator and it was cold as ice, so it was not circulating anything at all
i thought maybe the thermostat had seized up, but i noticed it was leaking out of the water pump
so im thinking its the water pump--
my question is, is there any online guides to doing this? it looks tucked in there and i don't wanna just start unbolting stuff without reading up a little first
any responses appreciated
Old 12-23-2008, 09:02 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: 96 cavalier water pump
1) Remove the serp belt
2) Unbolt the old water pump.
3) Clean surface from old gasket and other junk
4) Install new pump with gasket to block
5) Re-install serp belt.
Honestly, one of the easiest water pumps i've changed in my life. The Ld9 2.4L and eco are all driven off the timing chains.
Its like a 2 out of 10... honestly.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 12-26-2008, 09:23 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
on my 98 i removed the coolant resivior and the alternator. it added about 5 minutes to the job and made it a whole hell of alot easier
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 12-27-2008, 01:22 AM
txpelon txpelon is offline
how many miles does this car have and more important when was the timing belt last changed? if your going threw that trouble might as well check it if not change it. leaking water pump usually indicates pump is failing or has faild
your overheating problems could be caused by a jumped/failing timing belt
http://www.autozone.com/shopping/rep...00c1528003cbf6
Old 12-28-2008, 08:11 PM
thanks a lot for the responses, its a 2.2l, the car has 83k miles or so, hasnt had a timing belt change
gonna knock it out tomorrow morning
Old 12-29-2008, 12:47 PM
alright, water pump is on, im about to see if it over heats in about an hour or so
the water pump seemed fine that i took out...it spun without fuss, im hoping it WAS the water pump
if something is wrong with the thermostat, how do you get that out? is it through the neck under the exhaust manifold? thats where i thought it'd be from looking at it, i couldnt find a repair book at advanced unfortunately
Old 01-01-2009, 08:30 PM
http://www.autozone.com/shopping/rep...00c1528003cd06
