Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 12-22-2008, 08:18 PM
00Bravada 00Bravada is offline
Power window motor replacement????
I was wondering when I drill out the factory rivets on the motor and remove it will the window itself drop and do I need something to hold the window up and in place? Thanks
Old 12-23-2008, 08:48 AM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
Re: Power window motor replacement????
Yes.
Run a long piece of tape from one side of the window up over the top to the other side - actually, I used 2 strips. If you don't, it'll fall into the door and quite possibly shatter...and that's a mess you don't need to deal with.
I don't know about the '00s, but the rivets on the door of my '93 were so beefy and hard, it was quicker and easier to take the die grinder to them. The ones holding the window motor to the regulator were lighter and drilled out in a second or two.
Oh, that reminds me: use a C-clamp to hold the spring in place before you drill out the rivets holding the motor to the regulator. It's very important...
1993 Olds Bravada 4.3L CPI
1999 GMC Safari SLE AWD
2002 Chevy Astro LT AWD
Old 12-23-2008, 09:32 AM
Thanks. The next time I have more time on my hands to take door apart I will remember to use the C-clamp.
Old 12-23-2008, 05:23 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
When I did the motor on my '92, I took the end of the motor itself off. There are some tabs bent to hold the end plate/brush holder in place. I just bent them out straight.
After removing the end plate, I found gear grease covering the brushes, motor commutator and bi-metal overload piece. I cleaned these with carburetor cleaner, bypassed the overload then re-installed everything. Works good now.
Old 12-23-2008, 06:32 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Originally Posted by Leeann94astro
Yes.
Another great use for duct tape, just put some plastic wrap over the painted frame first.
And I used a Dremel with a cutting wheel instead of the die grinder, much easier to get into tight space with.
Isn't the overload also the up and down limiter, or shutoff?
Old 12-23-2008, 06:48 PM
Should have been more specific - this is a mini die grinder, or a pneumatic Dremel - whatever you'd like to call it
Old 12-24-2008, 11:37 PM
AF - Advisor
I don't know Eric, there's nothing for it to contact with like a button or lever. Is tripping the overload a good way to stop the motor after the window closes?
Old 12-26-2008, 06:23 PM
ericn1300's Avatar
AF Premium User
Yeah, no limit or zone switches, it's been my undestanding that the power windows and antanaes work by resistance, the overload is the only thing i can think of that would be triggered resitance. Guess it wouldn't be a problem except with the auto down feature since nobody holds the switch down too long.
