Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-22-2008, 10:56 AM
Captain Planet Captain Planet is offline
2000 SUburban high beam issue
The driver side high beam stopped working a few weeks back. Bought a new bulb but it wasn't the problem. There is no power at the fitting that plugs into the light. I traced the wire back as far as practical and can't see any nicks or exposed wire. FUses are fine. I am afraid that this problem is going to be caused by the wiring harness near the steering column that I have read about on other threads. Anyone have any ideas?
Old 03-23-2009, 11:39 AM
Re: 2000 SUburban high beam issue
bump..........
Nobody?
Old 03-26-2009, 08:54 PM
j cAT j cAT is offline
I'll look this up on the wiring diagrams,,,,tomorrow...this should not be that difficultexpensive to repair....
Old 03-26-2009, 10:47 PM
RahX RahX is offline
You have to have a bad spot in the wire. The left hi/low are fed from the same fuse. The high beams are both grounded together.
Old 04-01-2009, 11:46 AM
I'm just about due to do another oil change and tire rotation so I will try once again to trace the line. Thanks.
