Go Back   Automotive Forums Car Chat > Jeep > Commander | Patriot
Old 12-22-2008, 09:52 AM
squeak024 squeak024 is offline
07 Jeep Commander air tire light
I recently had a small leak in one of my tires. I plugged the tire and every sinve then the low tire air light has been on. Is there any way to reset it or do I need to put the tire back in a certain position? Any help would be appreciated.
Old 12-22-2008, 09:38 PM
Dodge_SRT Dodge_SRT is offline
Re: 08 Commander air tire light
yes you will need to put air back in the tire there should be a sticker on the driver door saying what it shoud be at +/- 2psi is ok
Old 12-22-2008, 11:06 PM
hundahunta hundahunta is offline
check all tires 35 psi even spare drive vehicle over 25 mph for 10 minutes or more
Old 12-29-2008, 02:30 PM
gogusgo gogusgo is offline
Be sure to check the spare. That did the trick for me.
Old 01-19-2009, 06:01 PM
dcx96 dcx96 is offline
The sensor needs to be reset, you cannot just rotate these either every time the need to be reset to tell computer where the tire is at on the vehicle. also have a dealer check to see if the sensor has a small weld damage, this is common.
