Old 12-21-2008, 08:09 PM
89cavwagon 89cavwagon is offline
89 Cav 2.0 Hesitation Problem Help!!!
I Have A 89 Cav 2.0 It Runs Great At Idle And I Can Drive It If I Stay Out Of The Gas And Just Give It A Little At A Time But When I Give It More It Sputters And Pops !! When I Let Go Of The Gas It Runns Smoothly Agian Just Have To Give It A Little Bit At A Time.
Cleaned Fuel Sytem From Tank To Fuel Inj.
New Wires New Plugs
Any Help Would Be Great
Old 12-21-2008, 08:32 PM
txpelon txpelon is offline
Re: 89 Cav 2.0 Hesitation Problem Help!!!
New Wires New Plugs
you dont give much info, how many miles, head/engine work done recently?
sounds like a valve problem, sticky or not seated properly could be one of many reasons.
when you say pop, what do you mean??
Old 12-21-2008, 09:06 PM
206,000 Miles Just Bought The Car For 150.00 It Runns Great Exept For The Hesatation I Think The Poping Is Because Its Loading Up With Gas.. Could It Be Tcs ?? Don't Konow Much About Car
Old 12-21-2008, 09:16 PM
well @ 206k miles and no knowledge of what has been done with the car. im sure work has been done on it however im not sure on what electronics/senors or on this car that can produce your problems stick around see if more input comes in
if no work has been done, well i would suspect bad valves, but again it could be many diffrent things causing this, and this is only one possible cause
