Old 12-21-2008, 03:39 PM
tccox tccox is offline
02 GCaravan, no dash lights
All fuzes in box under hood check ok. Lights just suddenly quit. What to check next? Thanks, Tom
Old 12-22-2008, 11:10 PM
hundahunta hundahunta is offline
Re: 02 GCaravan, no dash lights
was your vehicle just recently worked on...what about the radio, hvac lights
Old 12-23-2008, 01:29 AM
discnik discnik is offline
The wiring diagram I have shows that all of the feeds for the I/P lights come from the BCM. They have a common ground G200. I would think that this ground can be found behind one of the kick panels. Check this and make sure the connection is clean and not corroded or loose.
Old 12-23-2008, 01:10 PM
Talking Re: 02 GCaravan, no dash lights
Thanks guys. Vehicle has not been worked on. One day the lights worked, next day nothing. About the radio. Well, it has quit also. Not at the same time, several days later. I think it is in the thing that turns it off after a short delay. Sometimes before it died, the radio would start making a sort of squeel/buzz. I would have to manually turn it off to stop the noise. It would actually turn itself off but later it would start the noise.
Any thoughts on that? Where is the delay module or whatever it is called located?
I'll go out and wiggle some wires to see if I can locate the ground. Biggest problem is at night and no dash light to light up speedometer.
Thanks for all help. Tom
MERRY CHRISTMAS
Old 12-23-2008, 02:40 PM
cbwilsha cbwilsha is offline
I don't know about your radio problem but make sure your dashlight dimmer control hasn't been set to minimum, which is off.
C.B.
Old 12-23-2008, 02:45 PM
And even if it appears okay, run it up and down from min to max and back several times leaving it at maximum.
C.B.
Moderator: I tried to EDIT the previous post to add this remark only moments after posting and I couldn't resulting in this second post.
