Old 12-20-2008, 08:47 AM
metaxa44 metaxa44 is offline
Lights do not shut off ...HELP !!!
NEED HELP !!!
My lights are not turning off at all after I shut the everything off...
I had to disconnect the battery ..
It is a 99 caravan 3.3 engine...
Anybody had this before???
What should I do???
Thanks : Anton
Old 12-20-2008, 06:05 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Lights do not shut off ...HELP !!!
Headlights? Parking lights? Both?
The headlight switch tells the Body Control Module (BCM) to apply the grounds to the high and low beam headlight relay coils. Power is always applied to the coil. It's just waiting for the ground from the BCM to turn on the headlights. I would suspect either the switch or the BCM is bad. You've already reset the BCM by disconnecting the battery so we know a reset won't help.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
