Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 12-19-2008, 05:11 PM
Takest Takest is offline
98 Tc air suspension issue
last week i woke up and the rear end was on the ground, started the car, and it pumped up, stayed up. drove to the mall the next day, about 4 miles...while inside the mall it sank again, and would not lift back up.
the compressor kicks on, and i cant hear any leaks like some people have said they could.
unfortunatly because its 3 inches from the ground, i cant get under it to look for anything physically..im hoping i can fix it myself instead of getting grilled at a shop, considering how tight i am on money atm...
anyone have any ideas on how to isolate the problem?
Old 12-19-2008, 06:43 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: 98 Tc air suspension issue
You're going to have to jack up the car and inspect those bags. It's not easy but can be done. Don't forget to to turn off the suspension switch. Jack the car up and let the rear end hang down, it's the only way to see all of the air bags. Inspect the bags for large cracks by the base, check to see that height sensor is intact. Most likely your air bags are leaking.
Mike aka JYD
Old 12-20-2008, 10:42 AM
KManiac's Avatar
KManiac KManiac is offline
Sounds like a leaking rear airspring to me, too. These airsprings have an average service life of approximately 15 years. Some can fail sooner. Any holding air after 15 years are living on borrowed time. I just replaced the two front airsprings on my 89 Mark VII. This was a very easy repair once I saw instructions and pictures.
If the leak is slow enough that you can still raise the rear, at least long enough to jack up the car, then do so. Then turn off the air suspension by the switch in the trunk before raising the car. With the car supported on jack stands, you can spray the rubber portion of the springs with dishsoap and water to check for bubbles to see which one is leaking.
For replacement airsprings, check out www.bagmasterair.com . They have a good reputation and their rebuilt units are better than OEM and cost half the price. I have heard of other independent suppliers that are cheaper, but their quality appears cheaper, as well.
For additional information on airspring replacement, visit www.thelincolnmarkviiclub.org or www.lincolnsonline.com .
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
