Old 12-19-2008, 04:00 PM
MRVEGAS711 MRVEGAS711 is offline
Ain't sounding right!
Any thoughts on my 2005 Taurus starting to sound like a cement mixer over the last 10 days?
Took it into today to my Ford Dealership for a routine fuel filter change and I asked them to look at the exhust system. I was pretty sure I had a leak in the piping.
They could not find any exhust leaks and did not hear anything unusual driving it into the bay and back out. (On the verge of a blizzard here so no road test.)
Anyway, once I'm up to about 30mph and above, fairly strong road noise similar to a exhust leak, but apparently not. I kind of feel it in my feet so the origin of the sound so perhaps if right below me.
Any thoughts or similarities??
Old 12-19-2008, 05:30 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Ain't sounding right!
Wheel bearing?
Can you describe the sound a bit better? There are a lot of different sounds that can emanate from a cement mixer.
-Rod
Old 12-20-2008, 12:59 PM
Kind of a loud road noise sound as if any sound insulation I have fell off. I "feel" the noise in my feet (gas pedel) as in the slightest, but constant vibration.
Old 12-20-2008, 06:11 PM
auxbar auxbar is offline
I have the same thing on my 2003. The front passenger side tire used to bounce all over the place. Dealer said it was a tire issue, so I got some new tires and that helped a little, but the noise did not go away entirely. I'm not sure if the wheel is still bouncing all over - nobody has stopped me to tell me since I got the new tires. Before that strangers would tell me about it twice a week. It must have looked like it was going to bounce right off or something. I thought it might be wheel bearing, but sound and gas pedal vibration is pretty constant, not just when moving steering wheel to one side or the other. Post back if you find out what your issue is.
Old 12-20-2008, 06:16 PM
shorod's Avatar
SHO No Mo
Sounds a lot like a bad wheel bearing. Any experienced technician should be able to identify the sound of a bad wheel bearing during a road test.
-Rod
Old 12-20-2008, 06:17 PM
shorod's Avatar
SHO No Mo
Your description sounds like a wheel balance issue, which would explain why new tires made it better, along with a worn out strut in the front allowing a significant bounce.
-Rod
Old 12-21-2008, 11:30 AM
Thanks for the ideas, I do appreciate them! One last question before I take her in, does a wheel bearing problem sound like its covered under the warrenty? I have the original "bumper to bumper" warrenty for about 11,000 more miles. Asking as we all know that not everything is covered within those two bumpers!!!
Old 12-21-2008, 11:47 AM
shorod's Avatar
SHO No Mo
You'll have to check the verbiage of the warranty. I would think it would be covered under a powertrain warranty or the bumper to bumper, but I've never had one fail under warranty.
-Rod
Old 12-26-2008, 03:48 PM
And the answer is...........................
RF Wheel Bearing
Thanks for the advice Shorod!!
This was priced at about $300 to repair, with my extended Bumper to Bumper it was a $100 deductible and it took 1 hr to fix.
As Shorod and my service adviser said, a bad wheel bearing make a lot of racket.
Thanks again.
Old 12-26-2008, 08:12 PM
shorod's Avatar
SHO No Mo
You're welcome, glad to hear you got it fixed and it was covered under warranty! And also thank you for following up with the solution. That will likely help someone else in the future.
-Rod
