Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-19-2008, 02:58 PM
Davemcgolf Davemcgolf is offline
Turn signal and brake problem
I have a 1977 Cutlass Supreme. When I am using the turn signals, in either direction and apply the brake the signal slows to about one flash every 5 seconds and the side that is not in use flashes with the side in use but very dim. I relplace the flasher and both tail lights flashed together nice and bright until I applied the brake and then the stopped but the brake lights stayed lit. The front turn signal lights don't have the same problem of flashing together. all 4 bulbs and sockets look good in the tail lights. Any Ideas.
Dave
Old 12-19-2008, 07:02 PM
maxwedge maxwedge is offline
A990 racer
Re: Turn signal and brake problem
check for bad grounds in the rear then suspect the signal switch. Look at the bulbs closely also, sometimes the filaments cross over each other.
