Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 12-18-2008, 09:35 PM
jamx13 jamx13 is offline
Send a message via AIM to jamx13
2000 Venture driver's door speaker
The speaker in my driver's side door recently died. Since all Ventures seem to share a common list of problems (gas gauge, tail lights, power locks, hard shifting, wipers parking straight up, etc), I was wondering if this is just another one of them? Before I start ripping into the door, I was wondering if anyone else has experienced this problem or has any pointers as to what to look for. Thanks.
Old 12-18-2008, 10:03 PM
rockwood84 rockwood84 is offline
Re: 2000 Venture driver's door speaker
could be just a loose wire . before you tear in to the panel get some replacement panel clips,because some of the old ones will not be reusable.
Old 12-19-2008, 07:55 PM
kornjulio kornjulio is offline
Mine failed as well. There seems to be a water leak path down the wire harness. It corroded the speaker and stopped working. I replaced the speaker and it's all better now.
2000 Venture - repairs to date:
LIM gasket, water pump, wiper park position, front wheel bearings, rear wheel bearings, flickering lights, blower motor resistor, door speaker corroded, rear hatch handle, rear wiper motor, front struts, busted sway bar, LCA bushings, hard shifting tranny (new solenoids!)
Old 12-20-2008, 08:42 PM
roadrunner2 roadrunner2 is offline
Check the speaker wires where they run through the door post to the door as they MAY be broken inside the insulation from years of door opening and closing.
The problem with doing nothing is not knowing when you're finished.
