Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-18-2008, 05:10 PM
mattbirk mattbirk is offline
Where is the amp fuse located?
Where can I find the amp fuse? I looked on the amp itself and in the fuseblock with no luck. Also looked in the manual too.
Thanks
Old 12-18-2008, 05:25 PM
2005chevimpala's Avatar
2005chevimpala 2005chevimpala is offline
Re: Where is the amp fuse located?
Thanks
i think it's the same fuse as the radio,does your radio come on there is no sound,if so then you have a fusible link in your wiring harness that is corroded up,i had that problem too in my 05 impala,they replaced the amp but still nothing,in the rear pas side under your carpet ther is a wiring harness ther and you will see a orange wire that goes into each other like a 2 in one ,you will have to cut it off and rejoin with a new peice of wire,when this wire corrodes no sound will come from your sterio at all,it will light up but not work,i had a post on her last year about that and there were several people who had the same problem,let me know what or why u think your amp/fuse is gone
Old 12-18-2008, 05:28 PM
i saw your previous post, and looked for the orange wires by the rear pass door, but i saw 4 orange wires, and no where where they fused together. where is the harness? i basically untaped the wires from about the center door jam(where the front door closes in to and the rear door is hinged at) and untaped the wires about a foot. i didnt want to keep going, cause it could take some time, but ill try to give it a shot. but if you got a better specific location of it id appreciate it.
its a 2001, with sunroof. the radio does work, does show info, just no sound like the mute is on basically.
someone just told me to check the amp fuse which is why i asked that.
thanks
Old 12-18-2008, 05:41 PM
thanks
it's there i have fixed many of them in these cars,you have the harness located already in the rear right side,you should see 2 orange wires that go into one,cut it off and repalce with new wire,or where you see the 2 orange wires going into 1 pull on it to see if it comes apart,i can gaurentee thats where your problem is ,email me at [email protected] to let me know,mike
Old 12-18-2008, 07:29 PM
was looking at the pics,you are in the right area,go back toward the trunk 4-6 inches from where you are now,there has to be 2 orange wires going into one wire there,in the area of the rear floor,you must be missing it somewhere,it's the main power wire that powers your amp to make the sterio work
Old 12-25-2008, 09:29 AM
hey matt,keep your key on with the radio on at the same time and started moving and pulling on the wires to see if u get any better results,there has to be a wiring problem there somewhere in that area
Old 10-07-2010, 03:41 PM
ejbutler ejbutler is offline
Thumbs down stupid orange wires
I pulled the tape off the wires from the rear passenger she pillar all the way to the amp where is the bad splice on the 4 orange wires this is making me so mad
