Old 03-20-2003, 04:38 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
dashboard removal???
ok....i got it all out and unbolted and the wires are disconnected but i cause get the shit out.........when i try to take it up and out it hits the blinker thing and around the stearing wheel.....ths sucks i want to get it out to get it redone tomorrow.......if you guys have any help it would be helpful.....thanks
http://files.automotiveforums.com/up...46MVC-830S.JPG
Old 03-20-2003, 04:45 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
find the bolt at the bottom of the steering colum and take it out. Move you seat back and then it should drop all the way to the floor.
This is the real melt pizzle
Old 03-20-2003, 05:05 PM
Json79's Avatar
Json79 Json79 is offline
Send a message via AIM to Json79
No need... to do all that.. take off the steering wheel and the switcher... unit. for the turnsignals and the wipers.. u are only 1 nutt and like 3 screws away ...... good luck.. take the steering wheel off its alot easier..
Need an alarm, deck, dvd system for your ride?Or just want to upgrade with remote start,power door locks or windows?? Im Offering premier alarm/car audio installs for cheap prices. Your equip or mines. Questions...email me at [email protected] from the bayarea./ Nor Cali im also mobile so i can come to you.
'00 Yamaha R6
'90 Honda Civic Si Dohc Vtec My STKB16
FULL time Car Audio specialist/installer
AIM: Tuandang79
Old 03-20-2003, 05:11 PM
thanks i want even going to try to take the stearing colum........this will be alot easier....thanks im going to go do it right now
Old 03-21-2003, 10:59 AM
k i took my dash board and door panels off and i was wonder were i would take them to get them wrapped??? or how easy would it be to do it my self???...thanks
Old 03-22-2003, 10:04 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
theres another topic on here where i posted pictures of my dash reskinning. be prepared for a good bit of work, cause that ash is hella screwed and glued together. the stuff is stronger than liquid nail. its like plastic weld fused with epoxy. but once its apart, the actual reskinning isnt bad at all. just get some good fabric with a little stretch, and some 3M super 90 adhesive. clean all the parts with lacquer thinner first. CAUTION, the thinner takes all the color outta the parts, so if you arent sure you wanna jump in head first, then make up your mind before you start.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 03-22-2003, 01:05 PM
do you guys think it would be easier to dye or wrap my stuff???? thanks
Old 03-22-2003, 01:52 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Wrap!
dye can come off and chip
Old 03-22-2003, 08:36 PM
1990civic's Avatar
1990civic 1990civic is offline
its easier to paint, or die it. if you wrap it that will come off easier than painting it. just paint it right and it wont come off.
Upgrades:
Si Interior
Painted Interior
TACH
WW Body Kit
Clear Tail's (no altezza's here)
http://www.automotiveforums.com/img.php?129408DSC00972.JPG
****hopefully not the end****
Old 03-23-2003, 01:04 PM
1PhatCX's Avatar
if u wrap it right it wont come off also, clean it well, spray contact cement on it, lay w/e it is ur using on it smooth out wrinkles and let it dry before putting it in
Old 03-23-2003, 06:15 PM
el_loco_civic's Avatar
el_loco_civic el_loco_civic is offline
Send a message via Yahoo to el_loco_civic
Talking
the obvious thing to do here is just wrap it, then dye over the wrap.. so when the dye wears off.. you still got wrap ! :finger:
Civic - Trashed it
Integra - Hit and run totaled my ride after a couple 360*'s.. hittin guard rail at 80mph, literally FLIPPING over guard rail, barrel roll 2 more times, crashed front into a tree..
New Plans : Teggy / or / Tiburon
1993 Grand Caravan Dashboard Removal JohnnyPecs Caravan | Voyager 3 07-17-2004 04:02 PM
Dodge GC Sport Dashboard Removal gybrwe Caravan | Voyager 3 07-11-2004 04:21 PM
88 Camry Dashboard removal!!!!! Snickers33 Camry/Camry Hybrid/Vista 0 06-28-2004 07:32 PM
talon dashboard removal Chris4LCustoms Off-Topic 4 04-28-2004 12:51 AM
Dashboard Removal Help mkoko483 Century 0 01-06-2004 11:18 PM
